Hi All,
I have a 1500SP attached to a semi auto box.
Does anything need to be changed on the motor / flywheel to put it on a manual box?
I know there is a torque converter I need to remove but do I need to change the flywheel or anything else?
Flywheel and oil pump.
Oil pump is a 2 stage one for the ATF so needs to be swapped out for a normal one.
Thanks Joel,
What diameter flywheel am I looking for?
12 volt 200mm.
It's the most common one.
