my engine has not been started for 6 years,
im going to dump the oil, any suggestions on weather i need to oil up the barrels and what grade oil to use when i top it back up.
( JS )
Can you turn the engine by hand to determine if it is seized, i use penrite hpr 30, you could put a small amount down each spark plug hole and turn the engine over without the spark plugs in the engine. then start it.
