hi, is there any way to sucessufuly clean shoes covered in oil. thanks greg
mmm the right thing to do is replace them are they brand new?
i have seen them soaked in kero and cleaned with break cleaner
better off replacing them
but you could wash in warm soapy water then rinse in metho
There is a specific cleaner in a pressure pack called Brakleen, a CRC product, works pretty well, you cpuld put them in a warm oven after you clean them to see if any more oil comes out of the brake linnings.
Him much material is left? Is it worth machining down. Last on checked they Are cheap as buggery to replace
mate they are the only thing between you and a big tree replace, they are not price
Does it work on clutch plates too?
Remove and soak them in metho and set fire to them. Do not use kero. Use Brakeclean after as I doubt if it would work by itself.
Do not use kerosene it is oily.
Soak them in petrol for several hours and set fire to them several times.
If they still exude oil, get new linings.
It's worth a try.
