anyone used these shims?
http://www.spcperformance.com/index.php?option=com_spc&task=part_descript...
Even as the advert says, don't forget to check that the spindles bearings can accept the modified camber and toe.
As I said in your other thread, if the bearing does not have the play to allow for a variation in angle of operation then you will need the bearing
housing machined to the new plane of operation or cutting and rewelding the arm to the new angles
It is a nice product tho.
