steering shaft movement
homer - March 19th, 2012 at 06:07 PM
i can move the steering wheel in an upward direction. Is there a bearing on the shaft or an adjustment i can make? The car is a 74 beetle(non super)
grumble - March 19th, 2012 at 06:18 PM
The plastic bush that fits inside the bearing needs replacing.
68AutoBug - March 19th, 2012 at 10:33 PM
are these bushes available in Australia??
Joel - March 20th, 2012 at 10:00 AM
Definitly not one of VWs brighter ideas going from a metal bushing to plastic.
This is what you need.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C16-111-535D
1303Steve - March 20th, 2012 at 11:15 AM
If the bearing is OK youj can just cut a strip of plastic sheet and feed it into the gap, Idid this with my sons bug years ago and its still working.
homer - March 20th, 2012 at 03:53 PM
thanks for the info guys.does that bush have a thick wall as the shaft seems to move at least 5mm.
Joel - March 20th, 2012 at 04:20 PM
It feels like alot when the steering wheel attached but it probably has bout a 2-3mm wall
