Mods to seat frames
blup58 - August 22nd, 2003 at 03:19 PM
G'day All
Who can tell me the best way to get the seats shown below into a beetle....
My pan is a 58 and I was hoping to some how modify the seat frames to take these seats.
The seats have 4 bolt holes in the base of each.
I realise there is the legalality side of modifying the seat frames etc. What I want is a way that an engineer will most likely sign of on (assuming all welds are good)..but will still be simple and effective.
My thoughts without having looked to closely were to take my existing seat frames, cut of the bits I don't need and weld a couple of plates to the frames with holes to allow some bolts to pass through the plate and into the seats.....
Thoughts??? Has anyone done this before???
If I weld the plates to the top bar of the seat frame how do you think I will go on height and position???
Any photos of someone who has done this or links etc
Brad
blup58 - August 22nd, 2003 at 03:23 PM
Piccy
[Edited on 22-8-2003 by blup58]
blup58 - August 22nd, 2003 at 03:25 PM
One more try
Bizarre - August 22nd, 2003 at 03:35 PM
This is what i did
and another view
Bizarre - August 22nd, 2003 at 03:37 PM
Basically the new seat is welded to a VW base and it just slides on
You may need to support/raise/brace it to get it to the height you want but that is about it
Hey nice seats - 911??
[Edited on 22-8-2003 by blue74l]
vw54 - August 22nd, 2003 at 08:01 PM
Give us a pic of the base of the seats you want to fit into your car...
You have to try the height as you may need to cut the frame down
68AutoBug - August 22nd, 2003 at 08:25 PM
Yes, I really like those seats...
a bit better than normal VW ones !!!]
wadd - August 22nd, 2003 at 08:43 PM
great looking seats if it`s not a secret what they out of
555bug - August 23rd, 2003 at 12:32 AM
they look like 944 seats to me.
BiX - August 23rd, 2003 at 07:28 PM
here are some shots of mine. its qld approved. I think its like what u want to do. This seat is alot lower than standard. There is no rear leg room. Try using spacers to get the rite height. Iam a big guy so its nice to have it low and far back.
BiX - August 23rd, 2003 at 07:29 PM
closer view
BiX - August 23rd, 2003 at 07:30 PM
side view
