Beam Adjusters
guru - May 20th, 2012 at 09:03 PM
Has anyone had drama fitting these?
I've cut my linkpin beam in half and tried to fit the round leave block into the tube.
Sucker doesn't fit.
The block measures 45mm diameter. I have a mate with some 'avis style' adjusters from cip1 and the block is 44mm diameter.
WTF???
matberry - May 20th, 2012 at 09:43 PM
Crazy crazy....... CRAZY. Typical EMPI
The whole idea of the Avis adjuster is that you don't have to cut the beam......
68AutoBug - May 20th, 2012 at 10:41 PM
Originally
posted by guru
Sucker doesn't fit.
Trouble with EMPI chinese stuff..
it all looks the same but near enough is NOT good enough..
reason I have never had them they were always very expensive in Australia...
they are the way to go..
PS: EMPI trade mark is owned by Wolfsburg automotive NOT the mob that has these made...
vw54 - May 21st, 2012 at 07:19 AM
another QUALITY EMPI product
buy cheap CRY twice
Governor - May 21st, 2012 at 09:07 AM
I think you will find Wolfsburg only own the Australian rights to Empi, there is still a company in California who is using the name
EmpiĀ® COPYRIGHT 2011, EMPI INC. ANY REPRODUCTION OF, ALL OR PART, OF THIS CATALOG IS STRICTLY PROHIBITED WITHOUT THE WRITTEN CONSENT OF EMPI INC.
SHOULD ANY OF OUR CUSTOMERS WISH TO REPRODUCE PART OR ALL OF THIS CATALOG, PLEASE SUBMIT A DETAILED REQUEST IN WRITING TO EMPI INC, 301 E.
ORANGETHORPE AVE., ANAHEIM, CA 92801.
EMPIĀ® is a registered trademark of EMPI INC.
Some light reading
http://www.thesamba.com/vw/forum/archive/index.php/o-t--t-189600--.html
http://beetle.cabriolets.online.fr/gallery/kseume/empi.html
guru - May 21st, 2012 at 09:19 PM
Originally
posted by matberry
How do you get the lock out?
Am I the first to ever try fitting these??
matberry - May 21st, 2012 at 10:19 PM
I use the original, it, never leaves the beam.
68AutoBug - May 21st, 2012 at 10:50 PM
Yes
Mr BUG in the USA has all the bits made in China etc..
Taiwan etc..
psimitar - May 22nd, 2012 at 01:52 AM
I looked at these Puma type adjusters but the 2 broad dimples in my LP beam meant it woulda been a bugger to try and remove the dimples so I just used
sway aways.
Also the locating teeth on those cheap EMPI's are shite.
matberry - May 22nd, 2012 at 08:24 AM
^^^ I agree, re quality and a pain to fit. I use Sway-a-way style due to easier adjustment, altho I always recommend using front end braces as the
beam is weakened where the Avis style doesn't weaken the beam (if fitted corectly.......
vwo60 - May 22nd, 2012 at 12:38 PM
If the weld on the beam is done to the correct specs for the aplication it will not weaken the beam, a root run with the tig and cap run over that
will do the trick.
68AutoBug - May 22nd, 2012 at 07:44 PM
front end beam I've just fitted [with height adjusters]
off a 1969 German beetle..
My beam had a RH front wheel in positive camber..
so I'm hoping this one is OK...
