SC14
Newt - June 26th, 2012 at 01:50 AM
Hi Guys
Out of curiosity, can you run a SC14 blower upside down.
From browsing past posts, it seems they are ok on there side, but am I asking for trouble inverted?
Newt
Stanley - June 26th, 2012 at 06:42 AM
are you wanting to just run the blower upside down with carb on top or run whole setup upside down against the laws of gravity?
Joel - June 26th, 2012 at 12:39 PM
You could probably flip the gear housing upside down so the filler faces the right way up, pretty sure from memory the mounting flange is symmetrical but the breathers would be the main worry.
Newt - June 26th, 2012 at 11:14 PM
Thanks Joel, Ill have a look at the rear housing.
Stanley, I was pondering hanging the blower out past the dizzy with the exhaust facing towards the centre of the engine and the carbie / intake on the outside - but just pondering.
Newt
