Drivers side door hinge
gotthebug65 - July 3rd, 2012 at 08:36 PM
HI all
I am putting a new door on my beetle to replace the old rusty one before i spray it and i want to change the door hinge with the thread for the mirror
on it. I assume its a pin that needs to be pressed or punched out ? or is there another way to change it?
LUFTMEISTER - July 3rd, 2012 at 09:39 PM
Where are you located. Some one local may have tool.
gotthebug65 - July 6th, 2012 at 07:06 PM
Originally
posted by LUFTMEISTER
im near newcastle ill try and punch it out.... is the tool a clamp / press?
vw54 - July 7th, 2012 at 10:14 AM
dont punch it or you will loosen the rivets that hold the hinge on to the door
it has to be suported under it when its being removed
better off useing a clamp press
gotthebug65 - July 7th, 2012 at 07:30 PM
no worries i found a clamp for $30 that would suit the purpose....
cheers for the advice
Shuffs - July 8th, 2012 at 06:44 AM
Don't know if this will be of any help to you
http://forums.aussieveedubbers.com/viewtopic.php?tid=85049
gotthebug65 - July 8th, 2012 at 09:35 PM
psimitar - July 8th, 2012 at 11:34 PM
Originally
posted by gotthebug65
Where? Got a web link? Need to fir thread pins to my doors. Ta
gotthebug65 - July 19th, 2012 at 09:15 PM
Originally
posted by psimitar
http://www.1966vwbeetle.com/Forum/viewtopic.php?t=503&sid=afa4a7175a36624...
sorry mate lost the other link this might help though...
