hi, does the scat shifter fit the same as the standard shifter using the guide plate that goes on bottom of the shifter n mounts to the tunnel. thanks greg
Should have it's own internal reverse lock out plate. Have you seen if there is any further travel when the reverse lever is pulled?
My old Empi had an internal plate that lifted up for reverse to clear an internal lock out plate. Just needed a little tweaking before bolting tight
down to make sure all gears were available
pretty sure mine has its own lock out plate... i dont remember but i think i would as it would have been a pain in the ass to line it up if i had to use the stock one.
thanks for the replies, greg
