I know this is a how long is a piece of string question but here goes.
What would be normal oil pressure expected in the following setup.
New build 1835 twin 40 webbers scat C35 cam running full flow external filter and cooler and motor is now holding approx 4.5 ltrs of oil
Cold startup 29 psi
Warn idle 14.5 psi
Hot idle 11 psi
Cheers Ian
hmmm
If it takes a week to walk a fortnight
how long is a piece of string..
indeed ??
mate..
how about you put your data up here n peeps in the know may be able to give you some ideas?
What oil pressure is it at 3000RPM, 11 PSI at hot idle sounds alright, my 2054 is 20PSI at hot idle and 60PSI at 3000RPM.
Another few more factors that will affect the pressure are the bearing clearances,oil pump (HD 30mm gears or std),the length of the oil pressure relief valve springs,ignition timing and the oil operating temperature.
What is your oil pressure at 3000RPM.
