Soundproofing
baghall - July 22nd, 2012 at 05:28 PM
Anyone got any ideas on how I can remove soundeproofing similar to dynomat?
69bug - July 22nd, 2012 at 05:33 PM
dry ice?
can any one confirm this?
68AutoBug - July 22nd, 2012 at 08:23 PM
Originally
posted by baghall
Anyone got any ideas on how I can remove sound proofing similar to dynomat?
I think You have a job on Your hands
once the main stuff is taken off then the glue will probably remain
baghall - July 22nd, 2012 at 09:09 PM
Yeah thanks for your help Lee!
psimitar - July 23rd, 2012 at 12:46 AM
Heat gun and a large strong scrapper should get the bitumen/rubber up and then you'll need a solvent to get the glue off.
Can't think of anything mechanical that will make it quicker
bajachris88 - July 23rd, 2012 at 07:42 AM
Google is your friend:
http://www.ehow.com/how_7418768_remove-dynamat.html
Tells step by step how to remove dynamat by heat, and by dry ice.
68BUS - July 23rd, 2012 at 07:18 PM
Reading both of them the dry ice would be a better option to reduce the amount of warping possible in the panels would it not?
I assume extreme cold can also be bad for panels though.
baghall - July 29th, 2012 at 09:47 PM
Thanks guys. not looking forward to this as it's my fault the soundproofing is there in the first place. Bugger!
vlad01 - August 2nd, 2012 at 01:33 PM
wire wheel on angle grinder plows though that stuff, but be ready to clean the mess it leave afterwards. Sound deadened dust everywhere by the
mountain loads, vacuum cleaner with fix that though.
psimitar - August 2nd, 2012 at 10:19 PM
Originally
posted by vlad01
Heat gun and scrapper first to get rid of the majority and then wire wheel to clean up the leftovers
snitz - August 3rd, 2012 at 12:56 PM
Holding dry ice against vertical panels can be challenging..Ive seen vids if dry ice used for small dent removal by shrinking the affected
area..haven't tried it yet though...lol.
vlad01 - August 7th, 2012 at 04:07 PM
Originally
posted by snitz
I have, numerous times. Doesn't work
youtube myth I believe.
