running cold on3-4 cylinders
vwmanx - August 5th, 2012 at 04:51 PM
motor runs fine but cold on exhaust, twin weber 44 idfs,cannot seem to adjust air fuel mixtures hardly makes any difference,blown out idle jets and idle galleries,no difference has anybody had problems like this any input would be appreciated,cheers kevin
Bizarre - August 5th, 2012 at 06:03 PM
g'day and welcome
I am guessing it runs fine on mains.
If you pull plug wires 3 and 4 and there is no difference then you have a blocked idle circuit.
Your mixture screw must make a difference.
I would be pulling the carb and having a real good clean of them.
vwmanx - August 7th, 2012 at 03:33 PM
thanks for the reply i think i will have to pull it down and give it a good clean out,cheers kevin
