Small front tyres
Jenbob - August 15th, 2012 at 05:54 PM
Hay guys found similar post but nothing exact that helps, I'm new to oz and just got a beetle here, but it looks like a monster truck, back in the uk
we ran 145/65/15 or 165/45/15 tyres, just wondering what the smallest tyres you have out here and where can I get them? Thanks rob
tar76 - August 15th, 2012 at 06:06 PM
where bouts are you located? I'm running 165/50/15 on the front my bug. Thinking of changing them to 145/65's probably try my local tyre company?
whathaveidone - August 15th, 2012 at 06:13 PM
A friend used to run 135's not sure were he got them but
FROSTY - August 15th, 2012 at 07:26 PM
Hey jenbob, I bought 135 Nankangs from the local Bridgestone dealer only a couple of weeks ago, they had to get them in and it only took one day. They
cost $115 fitted and balanced (including a tube too).
Jason
FROSTY - August 15th, 2012 at 07:27 PM
sorry forgot to mention Nankang also do 145 and 165 too. (same price)
68AutoBug - August 15th, 2012 at 08:07 PM
Just remember that 70%+ of Your braking is done with the front tyres
and the reason for tubes??
incorrect rim size for Your tyres...
also remember that with a pucture with a tube they go down FAST... really flat...
also Your speedo will be incorrect
whathaveidone - August 15th, 2012 at 08:20 PM
You sound like the fun police Lee
would like to know how a tubless tyre goes down slower than one with tube????? Puncture is a puncture right
Jenbob - August 15th, 2012 at 08:50 PM
How tall are the 135? That's pretty narrow are they the space saver spare wheel tyre? Thanks lee il bear that in mind!
coletrickle - August 15th, 2012 at 09:29 PM
Originally
posted by 68AutoBug
70% of your braking maybe done on your front tyres if you are driving a commodore Lee.jenn bob give Big Tread tyres at capalaba a call brook the
owners a mate and a Vw pervert among other things he's my tyre guy.how'd you go at greeze fest?got the visor on?
matberry - August 15th, 2012 at 09:39 PM
Yep, got my 135's from Brook at Capalaba
Jenbob - August 15th, 2012 at 11:56 PM
Thanks for the help guys nice one, yeah grease fest was good some nice cars, sunvisors on, Pete at custom Veedub said he has never seen one put on
like mine, it's a bit crudely done, thank for that tho look well good on
MISS VDUB - August 16th, 2012 at 12:09 AM
Yeah we had skinny space saver type tyres on the front of our beetle and took them off, looked cool but were very dangerous in the wet.
tar76 - August 16th, 2012 at 05:31 AM
Originally
posted by matberry
Hey Matt i bet the speed camera ahead took a nice shot of the front!!
MISS VDUB - August 16th, 2012 at 05:52 AM
Top photo hey?
FROSTY - August 16th, 2012 at 06:27 AM
Nankang 135's are not space saver tyres ( sure they are small) they have a normal speed rating. I have had them on an early stock rims and also
5.5inch rims ( with a tube) .
Matt your 356eater is one nice machine!!!!
dragsters for life - August 16th, 2012 at 06:31 AM
i run 135 nankangs on front of my notch and have done for 2 years with no problems, i got mine at my local tyre place 100 each fitted and balanced
matberry - August 16th, 2012 at 08:14 AM
Originally
posted by tar76
posted by matberry
ha ha ...no pic in the mail yet Tarin.....thanks for the vote of confidence
Good shot eh? you bet. Cheers Ash
Definately no braking issues, correct tyre pressures is MAJOR important.
1303Steve - August 16th, 2012 at 08:48 AM
Not wanting to sound like a nark but you can raise or lower your tyres rolling diameter by only 15 mm from stock in NSW, I don't know where you are
but I think this is the case in all states.
Most people get away with it but if the shit hits the fan and an insurance company gets involved they will be looking for an out, incorrect tyres
would be an easy one to prove.
matberry - August 16th, 2012 at 08:56 AM
Originally
posted by 1303Steve
So I bet most of us are breaking the law then. The stock crossply's were 15mm+ over even a 165/75 IIRC.
donn - August 16th, 2012 at 09:34 AM
Lee is correct, puncture a tube and generaly speaking it's down like a two bob whore, puncture a tubeless tyre and the thickness of the rubber tends
to seal the hole and it holds the preasure loss down to a slow leak especialy if the nail or whatever stays in the tyre. HOWEVER, if you just clip a
kerb (or something on the road) and break the tyre seal the tubeless will go down like the afore mentioned tube where as the tube stands a good chance
of staying up, I did this once with a tubed tyre and actualy cut through the side wall of the tyre, stayed up for about 3 days till I could get it
fixed.
1303Steve - August 16th, 2012 at 10:44 AM
A 155R 15 is the excepted replacement for the 5.60 x 15 crossply that came fitted on Beetles VWs in the day, Type 3s and later bugs could run 6. x 15
when they went to 4.5 inch rims.
A 155R15 is 637.54 mm and a 145R15 is 617.22 mm, so about 20 mm difference, just as long as your aware of ramifications and are able to change tyres
in the event of a big one.
donn, what happens when you have a tube in tubeless tyre? Does it go down quick or slow?
donn - August 16th, 2012 at 11:03 AM
I understand that all tyres are tubeless these days, but that dosn't mean you can't use a tube in them, i have heard that sometimes a damaged or old
rim won't seal for a tubeless so they just use a tube, at present I have two front tyres on the Caddy that have tubes in them as I got a puncture in
one and the fella at the tyre shop in Adelaide said that he couldn't use one of those tyre repair thingies as they are illegal
so he offered me the choice of an internal patch (which seemed a
bit dicy to me ) or a tube, I decided on doing BOTH tyres so that they are both the same, if it wasn't for the fact that the tyres were almost new I
would have been better off replacing the tyres for what it ended up costing me.
snitz - August 16th, 2012 at 01:37 PM
Originally
posted by matberry
Nice stance Matberry..So you're running 135s and 215s?..Are they both on 5 or 5.5" Empi rims?..Just wondering what sizes to run on my wife 70 beetle
with 15X5 Sprintstars..
Joel - August 16th, 2012 at 02:26 PM
Originally
posted by 1303Steve
The modern day equivelent to the 6.00 x 15 is 165/80R15 which work out to 644.90m and the 1303 GSR/sportbug were 175/70 at 625.88mm so the tyre sizes
really were all over the shop
No wonder engineers have a coronary trying to work it out.
matberry - August 16th, 2012 at 06:24 PM
Originally
posted by snitz
Thanks Snitz. I'm running 135's and 225/60 both on 5" Radars from CIP1. The rear is stock early axles with type 3 drum brakes to get the wheel/tyre
combo to sit right and improve braking, the front is now a 2" narrowed beam with 2 Avis style adjusters and 3" dropped spindles that convert to a
disc stub.
For your later car, you'd need to fit short axles and larger brakes in the rear and a narrowed beam with dropped spindles and adjusters in the front
to get everything under the guards.In the rear a smaller tyre would get under the guard.
I was in the position where I had the tyres already and I like the big-little look and I also believe it's very important to keep the tyre diameter
tall for stock (or taller depending on engine) gearing.
68AutoBug - August 16th, 2012 at 09:55 PM
Originally
posted by donn
one and the fella at the tyre shop in Adelaide said that he couldn't use one of those tyre repair thingies as they are illegal so he offered me the choice of an internal patch (which seemed a
Some new cars come without a spare now and You get a repair kit.. some of the kits I have seen have the piece of rubber that is pushed thru the
hole.. with the tool to do it.. by hand... and some Fini-leak..
I remember years ago having a sidewall repair with one of those pieces of rubber sticking out the sidewall...
Tubes aren't illegal, but they can go off very fast with a puncture... I prefer tubeless..
but there could be many tubed tyres running around on 2 or 3 piece wheels... although a bit of silastic would fix those..
I believe all car tyres have tubeless stamped on them...
and that is to tell You that You can fit them without tubes...
many other types of vehicles still run tubes...
68AutoBug - August 16th, 2012 at 09:59 PM
Hi Matt
car looks great.. but a couple of years ago when I went to get My car passed for rego
[You know that NSW money making thing] My car wouldn't pass as I had adjusted My rear brakes up and it kept getting under 70% on the front
wheels
because My rears were working so well... lol
If I had type 3 rears I may never get passed... lol
snitz - August 16th, 2012 at 10:17 PM
Cheers Matberry..I am running 5" all round. Looking to run 205s on the rear and 145s on the front with 2" narrowed beam,adjusters and CB Performance
spindles.Atleast your pic shows me how the tyres sit on the 5" rims..Thanks.
bugboymatt - August 17th, 2012 at 06:19 AM
Some handy info in here, thanks.
Great looking ride. Matt.
vwo60 - August 17th, 2012 at 09:29 AM
A reducion in braking and handling all for the apearance, all illegal, a cop pulled over Nick from outrage trimming and he got 15 defects including
the front tyres being to small in relationship to the rear tyres, appearance over safety is the way to go.
