I tried to start our 72 beetle yesterday and just a clicking from the starter motor. No problem I thought, just a flat battery. I put it on the
charger overnight and still no good.
I hit the starter motor with a hammer in case it needs a tap to release it and still just clicking when I try to start.
Any suggestions on what else I can try?
Yogie
Jumper leads.
Sounds like the solenoid on the starter is gone. Shouldn't be too expensive to get fixed.
If you get a continual clicking it is electrical some how
If it is just the once, then could be the bushing
If you need a starter - let us know
I have a new one that I dont need
Thanks guys. It is somewhere to start.
Brett
The starter could be polling, the bush in the gearbox could be worn and this allows the comutator to touch the inside of the starter, common problem. to get the old one out i use a 12MM tap with a tap handle, it just taps a thread in the bush and pushes it out.
battery
I tried jump starting but no good there. The car starts fine with the clutch start and I hoped that may have freed up the starter a little but no
luck there. I don't have anything to measure the charge of the battery so can't do that.
I thought it may be a frozen up solenoid or something which is why I pulled out the hammer for a go at it. The starter was new when I bought it and
the car has only done about 6k since then.
Yogie
Hang in there Yogie i'm sure we'll null it out!
Can you get another battery on loan to try?
I hooked up one of those wheel around types of battery that have jumper cables attached permanently to it for the jump start. It was fully charged
and didn't work but I can probably get another to put in to double check though.
Yogie
Have you tried bypassing the ignition switch?
I wouldn't mind betting you just have the token VW worn igniton switch syndrome.
How did you go Yogie?
Was too busy this weekend to get in to the garage unfortunately so I will have a look next weekend.
Yogie
Cool keep us posted
I'm having a similar issue with my 71 bug...
Where should I start looking to bypass the ignition switch?
I want to try this because I don't even get a clicking at the starter motor, which suggests to be that power isn't even reaching the starter.
