Saw this and thought it was a pretty interesting setup to share. You'd want to have a fat wallet at $4400 starting price per pair. But uses stock
style performance cams, push rods, tubes, barrels, flat top pistons etc.
The volumetric efficiency benefit would be the saving grace for any super hypo engine i would assume.
here:
http://www.araoengineering.com/vwheads.htm
http://www.youtube.com/watch?v=3KERkb7SaH8
That video is mentally funny
What a hideous rocker arrangement for the second set of valves!
Double the rockers, double the friction/wear points, double the mass. Those heads are huge chunks of metal too, and it doesn't look like they'd cool
too well. Not for me thankyou. A very interesting exercise though, to try and cram four valves per cylinder into a pushrod engine.
I did notice revs did not go too far past 6K. Must be hell on pushrods
(unless my labrador is deceiving me)
It would be two cartons to do the tappet clearence, you would have to juggle two feeler gauges.
Interesting. Don't think I'd bother either. 2332 making 235
Now compare with a JPM 1915 making 248
http://www.youtube.com/watch?v=JtpzA0hd8Kg
AND ONLY 2 VALVES per cylinder
these heads= what a waste of time and effort.
I'm not sure why they have gone with such a complicated rocker setup.
The engines we rebuild at work are 4 valves per cylinder pushrod engines. They simply have a small metal 'bridge' between both valves and the rocker
arms pushes down on the middle of this opening both valves.
I'm not sure why you couldn't run a similar setup instead of all that extra crap.
The engines at work are low reving diesels though, they top out at around 2000rpm, and only make like 3500hp
So this setup possibly can't cope with revs.
Smiley
there are pictures of one in the Hot VW and dune buggy .
http://www.hotvws.com/issue_previewLrgContents.html
there is also a video on their facebook page.
^^^That one is twin overhead cam, way better but mega work, interesting that it pulls 10500rpm also
What i find exciting is simply the concept of the cross sectional area in total of the valves compared to 2 valve per cylinder.
You would hope the rockers were super light. Overhead cam would be fun for tuneability, i'd have to take a sticky beak :P
