L Bug Steering Boss
TorxKiwi - September 26th, 2012 at 08:53 PM
I picked up a great set of Golf seats on 3-point runners from 65busser and put the drivers seat in last night. All has gone well but its now a bit of a squeeze for a fat bastard like me to fit in under the steering wheel.
I have a smaller steering wheel which I picked up a while ago, but the boss kit I got off e-bay is crap. I can fit it but if I turn the wheel I have lights flashing on high beam, the horn blaring and God only knows what else happening as everything shorts out.
Does anyone have a boss bit that will fit an L Bug that they are looking to sell, or can someone recommend a supplier of a decent one?
68AutoBug - September 26th, 2012 at 10:36 PM
Its a common thing with VW bosses...
they are way too short...
I did see one that someone had added a bit to the boss to make it thicker... lol
with an L bug You may need to check the size of your steering shaft splines..
they changed to the Golf size but not sure when [what year]
so they were smaller shaft..
Best of luck..
PS: Yes the steering wheel is too close to Your body getting into a beetle and getting other seats to fit perfect can be difficult too.. there wasn't much room either side of the original seats
Joel - September 27th, 2012 at 07:29 AM
Dean, you just need to adjust the air gap between the steering wheel and the switch gear.
If you have a look under the dash you'll see where the steering column bolts up the holes are slotted so you can move it up and down to change the gap.
TorxKiwi - September 27th, 2012 at 09:08 AM
Awesome. Thanks Joel .... it was giving me the absolute shits in the half dark last night!!!
