Hi everyone,
Thought you might like to see the shell I picked up to replace the rotted out one I had.
It's a '65 and has been painted more times than I could believe. But still... It's straight as a dye and has one tiny rust spot at the base of
where the drivers side guard bolts on.
I decided that a bare metal respray is the only way to go so took to a couple of panels with the paint stripper this evening.
Cheers,
Cam
Looks good. Quick question though. Does the cling wrap over the paint stripper really help? If so i will give it a go next time. Heard it keeps the fumes in etc and fastens the process.
I've found it actually stops the paint stripper from evaporating and helps the paint come off in larger strips as opposed to small flakes. Which is a problem particularly when doing the stripping outdoors in 30 degree heat.
Hey fellow dubber,
Just thought id mention that i fabricate rolling body and floor pan jigs/frames.
Beats sitting em on drums or jackstands.
U2U me if your interested and i will send pics and prices.
Yes they make life bloody easy and are not stupidly priced.
Also no worries with shipping it to you.
U2U sent, dude.
Thats what I am making for the bus too Cam, the jig...
Off and running mate!
