here's some pics of my bus.
finally got it back after getting the g'box built.
now has brand new Albins super diff, Albins 3rd, and Albins 0.70 4th.
put the new rims on tonight. they're ROH adrenalines, with 245/45 17's.
put some new adjustable Koni's on there too.
still would like to bring it down another inch or two at the front, and at least one more spline at the back.
here's one of the wheels.
and in the back, it's got one of these :bounce
I'd still like to lower it another 50mm al least.
cant wait to run it down the 1/4 mile on jan 8th.
there, that's a better ride height.
thats one nice and clean looking bay , how does the motor go for cooling i am guessing the radiator is underneath the bus somewhere, i have heard
different stories about cooling issues in regards to radiator placement,
also if its under the bus and you go another 50mm lower will it be close to lets say a speed hump, just curious as i was going to fit a v6 in my bay
i had a while ago but didnt want the radiator sitting on the front bumper
if i get another bay as a daily driver this is the power plant i will go for
it has a radiator from a hx holden v8.
that's the largest off the shelf rad. that will fit between the chassis rails.
there has been no overheating issues since the thermostat has been changed to run a little cooler, there's also two big thermo fans on the back of
the rad sucking air through.
if you look just inside the front right wheel in the first pic, you can just see the duct that sits up front to direct air through the rad too.
The only clearance drama I can see straight away with lowering it some more, is the exhaust at the moment runs below the g'box.
this will have to be changed.
good luck with yours.:beer
that a very smart looking bay indeed!!!! looks the shizzle!
rhys
keep your eyes on the cars for sale section very soon.
that looks hott. post a pic of the radiator.
wacked1
if you sell it, what you going for next, it's gotta be a V6 splitty!!
was thinking about that, but got something else in mind.
Bet your thinking about turning the 54 into a Baja-cool??????
don't tell anyone will you Gary?
Looks very nice now...but you're right it will certainly look a treat once it squats down a little lower!
here it is with the old wheels.
which wheel do you guys think look better on the car?
Neither-put the original steels back on with some of those chrome look hubcaps that imitate a set of mags.If you were a good boy last year-there should have been some in your Xmas stocking.
nah i like your big chromies better
trying to find some wide 13"s for it, but can't find any for 5x112 pcd.
The ROH's look the goods for me.Do you want the 13's to be mags or steel rims?
