Indi's Beetle
Midlife crisis - September 28th, 2005 at 06:26 PM
here are some pictures of Indi's project
Midlife crisis - September 28th, 2005 at 06:27 PM
more
Midlife crisis - September 28th, 2005 at 06:28 PM
And this is the what the final will look likenn[ Edited on 28-9-05 by Midlife crisis ]
Indi - September 28th, 2005 at 06:32 PM
I have just started to bring these fiberglass kit cars in from the US.
I am trying to get the first one on the road, I am learning heaps as I go. The more I learn about VW's the more I love them...
They are called the Wombat in the US, I was planing on calling them the Combat in Aus, However that name is taken by rover mowers. So no name as yet.
My web site is http://www.xcars.com.au
It will be fully operational after the first one is on the road...nn[ Edited on 09-03-2005 by Indi ]
ruckus - September 28th, 2005 at 06:33 PM
Hmmm so why the ball joint pan when the bug's got a mcpherson front end? or is it a late standard? Looks like a super to me.
#edit# (I clearly have no idea what I'm talking about!)
[ Edited on 30-9-2005 by ruckus ]
Indi - September 28th, 2005 at 06:46 PM
The Bug is only for the engine ...
The the ball joint pan is what I will be using
bajachris88 - September 28th, 2005 at 06:59 PM
Hey Indi, that yellow one is awesome. Can't wait to see what u got on ur site when its all up, i will definitely look forward to seeing it.
Good luck with the project to mate.
Oh, and one thing. Was a little confused, and tried looking on the net for images to see, but whats the visual difference to tell a ball joint from a K & L front beam?
Chewy - September 28th, 2005 at 08:25 PM
Easiest way to tell is a K+L beam has straight shock towers ball joint ones curve outwards at the top (K+L shocks mount with a bolt and BJ use a stud)
Also BJ has no bumpstops, the torsion tubes are spaced closer together, and more importantly uses ball joints insteal of pins!
R.FRAGMEYER - September 30th, 2005 at 09:25 AM
None of the pans above are ball joint.... maybe i missed somfin... just fyi
R.FRAGMEYER - September 30th, 2005 at 09:26 AM
cant wait to see it too.
Indi - September 30th, 2005 at 10:06 AM
Thanks guys,
I thought that it was a ball joint, however I now realise that it's a K&L pin.
It's all a learning curve, I'll get there in the end.
Cheers..Jon
Chewy - October 14th, 2005 at 05:35 PM
I meant to say BJ beams are spaced further apart there.
