Ok so it's time for me to start talking about Frederik the '54. I pulled it apart last weekend so I could get a better look behind the fenders etc
and was very happy to find only a few problem areas.
1/ Front left firewall/heater channel ext. has had a dodgy repair job and needs to be re-done.
2/ Rear bumper mounts both look pretty sketchy and need to be re-done.
3/ Rear left Jacking point seems to suggest that the left firewall might be a bit of a pain in the arse.
4/ Bottom of decklid again has had a dodgy repair done to it and probably needs to be re-done.
5/ Bottom left corner of windscreen and the leading edge lip under the bonnet both need attention (Don't know how to do this one as no one seems to
make repair sections).
I'll have some pics of the problem areas in the next week or so after I go down to G-town. If anyone's got any comments/suggestions please feel free
to go nuts
Oh, and sorry for exposing you all to Chris' hairy navel again.
Yay for school Holidays!!!!
Yeah I know Doc, Rhino comes first.
[ Edited on 23-12-05 by ruckus ]
What are your plans for Fred then....? :P
Late swing pan (the one currently under Elmo), narrowed adjustable bj beam (sitting next to Freddy at the moment), dropped spindles maybe, NB 17"
Brms or 17" Radars...
Then sell the bastard
At least the paint is already sorted.....
pics:
(details later)
left:
right:
Annoying hole in the other side found today:
Few little holes at the base of rear window. I assume these can be welded up?
Couple of holes in the rear corners (internal) either side of the window:
Couple of tiny holes at the base of the curved bit (can't really see them):
If you didn't have a hobby before, well, you do now!
17" radars? where do you get them?!
*cough* bling *cough*
17" radars,
you get them,
and we'll try them out on mine, and see how they look.:tree
Sure Ross. You can pay for the custom brakes for them then...
hehehe
well I've got a the complete, ready to go, twin leading shoe, drum brake set up.
would that help,
Best way to reapair this area is with a mig and a block of copper.
You place the copper under the bottom and weld from the top and biuld it all back up. Takes a bit of time, but gives a great result. Saves cutting out
a huge bit of metal and try to make something to fit.:thumb
there you go rob....
Nathan you are an absolute legend!!
No xmas presents for you
You must have Freddy in a manger and JC is missing from his cradle
:beer:beer:beer:beer:beer
OR
The three wise men came in a dub
How cool is that
:thumb
I've got a good section for the rear of the front hood ie in front of window screen I'll try and cut it out so you have all /most of the bottom
screen rust hole repair but at least you'll be able to repair the big rust hole in the bonett closing gap
U2U me
Cheers nIck
My panel beater told me this great way of welding up pin holes. You get a thick flat piece of brass and hold it up agains the underside of the hole, then you just MIG weld up the pin hole and grind it back. Works a treat coz the mig won't stick the brass and the brass soaks up some of the heat so the weld can't blow out as easily.
Looks like a good one to keep your weekends busy for a while. If you need a panel beater for some of the more challenging bits, let me know, the head panel beater from my work is an old vw nut from years back and is always doing cash jobs, and he is only up in donvale so it could be handy. Anyway great find!
Just cut this out hope it will help you
You've got a u2u... and I'm happy!
Looks like you are going to be busy.
Did it come with all correct tail lights, bonnet, steering wheel, headlights etc?
The deck lid looks like a wide spring, did it come with the spring? These are the bits to look out for and I will keep my eyes open if you list what
your mssing. I have almost completed my 2 54's (in parts not resto) and will keep my eyes open.
Also, your rear bumper mounts didn't look so bad but you can get complete replacement panels from these guys. Excellent quality and fit. This is
where I am getting a few sections: http://www.wolfparts.com
Are you keeping it a rat or going the full monty? If your going new paint maybe consider acid dipping or sulfar blasting. Here's mine after
dipping:
Good luck.
T54
[ Edited on 4-1-2006 by Turbo54 ]
From the above to this.
Wow!
Thanks for the offer T54.
It came with heart tail lights but without bulb setup or heart lense so I'll have to get these repro.
I've got correct headlights (pretty sure as the glass is stamped 'bosch') and some later ones for spares.
Bonnet is incorrect (early 60s I think)
Decklid is going to be a big challenge and I'm not too sure how to approach it.
I've got seats for it in Adelaide but I have to get them over to Melb.
I've got the proper doors but one of them needs a big section replaced in it.
I can't afford to go full resto and I'm not going to be too precious about it. I'll get the fundamentals sorted, learn a few things and then
probably move it on to someone else. I'm going OS in a year so I'm still trying to sort out how serious I should be about the whole thing...
starting to think I'm going to have to sell it in a bit or put it in long-term storage.
[ Edited on 4-1-06 by ruckus ]
Oh and thanks to mr bubble head I think the biggest problem (so far) is sorted.
wish i had heart tail lights.....
Looks like a decent project Ruckus, when you go away, I think long term storage is the way to go - you'll have put in too much time and effort to
just dish it off to someone else.. good luck!
:o i had a 64 that looked worse and i got an expert to look at it and he told me to bin it.(wish i hadn't listened to him now) oh well good luck with it what ever you do
Ive got a pair of the heart bases and bulb holders, im guessing they are genuine, not nos but in pretty good nick...make an offer, just cluttering up my shed... also have a solid visor off a 54 beetle...and one of those air things that sit on the top of the window to feed air into the cab, still in its box
I've got bases but no bulb holders, but I'm guessing you don't want to part out.
Ive only got bulb holders...u2u me what you want to pay, give vintage in sydney a call and offer a bit less...they are in smick condition...
Cant wait to see her finished. Good luck mate!
Hey byronbus did you get my u2u?
