wheel offset for type 3
braken - January 2nd, 2009 at 06:58 PM
Well finally sorted a car and was wandering if someone might be able to help me out on some wheel specs. have to decide on buying either 4.5 mangels and run 145/65/15's. or 5.0 BRM's and run with 165/50/15. Anyone no which would tuck better on a 71 fastback.once lowered. cheers !!!!!!
Have done the 175/65/15 on 5.5 before to me a little too wide.
crunchyyy - March 25th, 2009 at 08:31 PM
Hey
Im running 195/50/15 on empi 8's, 5.5
maybe try this calculator
http://www.miata.net/garage/tirecalc.html
and compare heights, the 165.60/15 are .9 of an inch lower..
vwvic - March 31st, 2009 at 11:24 PM
My sister tried to fit 5" BRM four spokes on the rear of her notch and they were too wide.4.5" fitted on the front though.
Bizarre - April 1st, 2009 at 07:10 AM
Also use this
http://www.1010tires.com/WheelOffsetCalculator.asp
You need to know the ET (offset) of the wheels you have and want
Then this will tell you how much movement you will get
