Hi guys just after a loan of a Synchrometer to set up my webers.
In in the Wollongong area, if anyone can loan me one for a weekend that would be great!
Thanx.
If you can't get hold of one you can do it with the remove plug lead method.
Pull the lead from 2 & 4 cylinders from the cap so thatye can be easily removed, then loosely plug them back in.
Start the motor after having already warmed it up, then remove 2 & 4 lead in turn, adjust idle until you get an even drop in revs from both sides
and try not to get zapped.
