How do I post bigger pictures
turboL - December 5th, 2005 at 07:51 PM
I tryed to post some decent pics but at 50kbs they are too small how do I post something that is bigger but clear????
pod - December 5th, 2005 at 07:53 PM
try hosting the off the forum at http://www.photobucket.com  then just copy and paste the bottom link in your post
turboL - December 5th, 2005 at 08:19 PM
Ill try it thanx!!
Bizarre - December 5th, 2005 at 09:11 PM
read here
http://www.aussieveedubbers.com/forum/viewthread.php?tid=41621&page=1#pid384441
.... here is part of the answer
Do a search for " Irfanview " under my name.
Here is a cut and paste of one of my replies
You can use paintshop or one of those programmes or i use a free ware called Irfanview
you can download it at http://www.irfanview.com  and follow the links or u2u me your email and i will send it to you.
It really is easy to use this programme for down sizing pictures.
Open picture as jpeg
Click -
Resize – and set at 600 x 400 and nice large size
Then click –
File
“SAVE AS” and click options and there is a slider bar
Set it at 50
That should set the picture nice and big and only about 40kb
IF it is still over
click –
File
Set it at 30??
If you are over 50kb it says that...and just forwards you back to the site so my guess is you are over the 50kb limit.
It is quality not sive you want to reduce.
u2u me if you are still having trouble.
turboL - December 6th, 2005 at 09:29 AM
Thanx Baz Ill give it a goo!!!
vanderaj - December 6th, 2005 at 08:55 PM
I've increased the max image size to 100 kb. You can also use the gallery (see the links!) to host your albums - no nasty watermarks.
Andrew
turboL - December 7th, 2005 at 09:41 AM
Thanx guys
Midlife crisis - December 7th, 2005 at 10:12 AM
I use infrview since Bizarre told me about it a year ago, I followed His links it is easy to use.
Marc
