Hi there i've been building my Baja for about 3 years a
1970 swinger converted to iRS refreshed 1916 4 wheel
disc's simmons wheels and resprayed a metalic grey was
a complete off the chassis rebuild, i've got lots of pics all
on photo bucket , im with bigpond but on here it says
it's no longer avaliable how do i go about posting some
pic's, any help would be great . Mick.
Best way to post photos is to open an account at a photo sharing site like photobucket then posting the links in the thread
Trying to put up some pic's of my Baja project
an old pic scanned into pc, lower nose cone not yet fitted
Front valance cut off, Front end fully welded, shock towers guseted , and height adjusters fitted, all repainted and refitted to car.
Body rubbed back
Will fix small dent in 1/4 panel.
Found new (2nd hand) frnt guards off a cheeta kit to cover the frnt tyres and another kit a Bug eye to cover the rear tyres, starting to take
shape.
Guide coat ready to be rubbed off
The rear guards I found from a Bug eye kit are wide enough to fit the 31x10.5 tyres that I will use. I had to fill all the mounting holes then refit
the guards due to bad cracking.
My choice for the rear engine cover (part of). Once cut strenghth needed to be put back into the edge so I folded a ten mm lip over at black line.
This was very time consuming as two jigs needed to made to sandwitch the metal together before I could tap it over stop the rippleing, it worked a
treat .
