Hi, I started a thread and tried to attacch photos but they didn't load up. Is there a size limitation and are there any tricks to be aware of? My
pics were about a meg each.
thanks, Lou
pics have to be under 100Kb from memory
heres the last thread on it
http://forums.aussieveedubbers.com/viewtopic.php?tid=86488&page=1#pid808690
thanks guys. I'll try the email trick as this seems the easy one to start with ans see how it goes.
I tried the email method and used the smallest size and it worked like a charm.
In case anyone else needs to know;
1. email the photos to yourself and before you hit 'send' resize them to small
2. recieve your email and copy photos to a new folder, I named it "small pics"
3go back to the thread and attach the new photos.
too easy! thanks again barls...
Lou
learn more every day. If you want to attach photos to an existing thread as a reply you have to use the "new reply" botton on the right hand side of the screen and not the "quick repy" box as you can't add photos in the quick reply.... Only took me three weeks to work that out.......
Test post pic from iPad
see if this works
it is difficult at times to operate this site....some might say its me......maybe but i guess the fact that
there is a section here for beginners questions is great.....which might also answer my question that
it is a diffcult site to monouvre in......
This stuff helps heaps
so how do you attach multiple pictures to the same reply?
I end up posting several replies each with a picture. Would be good to add all my pictures in one reply.
I've seen others do this using links to imageshack etc but surely there's a way to upload multiple images to the one reply... isn't there?
if you upload your photos to photobucket you then copy the img links to the reply and you can get multiple photos in 1 message
just like above
Kermit
my red 69 bug for sale in sale section
