Hi Has anyone had trouble fitting a alternotor to a 1600 motor. I cannot fit the carby. The linkages for the accellator pump hit the alternator.
Can any one help
Thats correct
There are 2 different set ups
I have seen people grind away sections of the alternator
Pretty sure you can flip the linkage around???
Otherwise you need a different carb
I just took a grinder too it. few minutes and problem solved. The side of the alternator has some pretty thick flesh, its hard to go all the way through it.
