Hi all,
I'm from Adelaide and new to this website and new to restorations. This looks like the place where I can learn and ask questions!
We have had a 1961? (chassis # 3741619) VW beetle in the family for 20 years. My sisters drove it before breaking it. Lack of oil was a
problem...which I think led to a cracked crankcase? not completely sure, I will be looking into it soon enough. Think the engine is a 1200 with big
bore kit.
The beetle was in solid condition and still garaged until 4 years ago when we shifted house and had to store it outdoors. It has sat there half
stripped collecting dust and rust (hopefully mainly surface rust). The engine is still together but out of the car and covered in rust.
I now have a shed for the car, my aim was to strip the car and possibly sell the parts. However, my enthusiasm for the beetle has got the better of me
and I am now keen to restore it (fingers crossed that there isn't too much rust)
Anyway enough from me for now, I will add some photo's to this thread of the beetle shortly. Looking forward to the chit chat.
When you say resto it, dou you mean bring it back to it's former glory, or did you have another plan in mind?
Just to have it running would be nice
I guess it wouldn't be exact
origional condition, but no major mods. I would like an origional colour, with all the crome and origional interior. I will keep the current engine if
it is save-able! A little lower than origional would be nice.
Money is going to be an issue, but i dont mind taking my time and learning along the way.
I have no plans for it to be a show car...but something neat would be nice.
Well you are in the right pace here. There are loads of people who will be able to help and loads of places to get spares. If you need anything just ask and no doubt peope will be able to help you.
J-Rod
Iam new too to the forum and have a 64 Beetle been in the family since new... Still goin.
Get it on the road bloke, grab a 1200 engine and drive it
cheers and best of luck
Here are some pics of the bug sitting outside. Lots of work ahead!...plenty of rusty parts
Soms more pics
Which suburb do you live in and what do you need help with?
Dave
Hey Dave,
I live at Mawson lakes, but the car will be at Modbury until I rent a place with some room. Not sure what I need help with yet, I'm sure i'll figure
that out once I start!
Finally moving the 61 beetle indoors this sunday!
Just checked the engine numbers, the one in the pic above and still together is a 1300...will have to see if it can be cleaned up and saved. The other
one, which is in pieces is a 1200 with big bore kit (this one has a cracked engine block and everything completely rusted).
It's a long way down the track, but any thoughts on my best engine option...try save the 1300? Look for something else? I'm not really interested in
the power.
I want to atleast have a play with the 1300 to learn a bit more.
Starting with some basics...The first thing you need to find out is the condition of the bottom end, ie main bearings. They are the backbone of your
engine. Building an engine with worn main bearings is like building a house on dodgey foundations.
1300 and 1600 engines use the same (69mm) crankshaft. The difference is in the size of the piston. If the 1300 (77mm) pistons and cylinders are
reusable then stick with them. If not, the 1600 (85.5mm) piston and cylinders slip straight in and are the cheaper option to replace.
1300 cylinder heads will need to be machined to suit 1600 cylinders and have the same size valves as 1200 engines. Again if the heads need replacing,
you have the choice of using single or twin port heads.
Cheers Dave
Thanks Dave,
I'll get the engine apart, and have someone with better mechanical knowledge check it out with me. I have a VW book ordered for my xmas present to
help! I know the heads were reconditioned just before this engine died (think thats when it had an oil leak and my sister forgot that!)
Fingers crossed the cylinders and bearings are ok...time will tell. Do the 1600 cylinders fit in the same case? excuse my lack of mechanical
knowledge.
Thanks again
Q...Do the 1600 cylinders fit in the same case?
A...Yes. if it is a 1300 crankcase, 1600 piston and cylinders slip straight in.
PS...a 1300 single port engine number will start with the letter "F" followed by six or seven digits (numbers) ie F1972222
Thanks!
Yea it's a 1300 F1070615
Update - we have finally begun work on my 1961 beetle. We now have somewhere to work on it, now for the fun.
Time to complete stripping the car and separate chassis and body.
I'm starting to look for some information on body and paint for my beetle. Does anyone have a good reputable location in SA who will paint my bug or
has experience painting beetles?. I will do as much of the prep work as my skills allow (not sure how much that is yet), but I want to pay for
professional job. I understand this can get very expensive, but just trying to get some leads going.
Still not sure on acrylic or 2 pack either, anyone here had experience with either?
Thanks for any help!
Anyone got a good blaster they've used in South Australia? Was looking into dustless blasting, but I understand the sand blasters remove most of the
excess and should be professional enough not to warp or damage the metal.
Looking for someone who also finished the car in a primer or rust proofing of some sort so I can take the car to my panel beater/painter.
Cheers for any advice!
The sandblaster is very important and you should ask to speak to other people he has done work for on their cars to see what they think of him. They
can cause lots of problems if they are not careful. My sandblaster in Brisbane was an ex panel beater so he knew what to do. I would also be double
checking and getting my compressor out to make sure all of the sand is out of all of the nooks and crannies. The heater channels and napoleons hat as
well as the tunnel can hide lots of the sand.
Good luck on your search.
Yogie
Thanks Yogie, I spoke to someone today about sand blasting. They were very honest about the pro's and con's of sandblasting and other stripping
methods. They blast cars for some good car restoration companies and have a good understanding of where they can and can't blast safely.
I'll be taking the car to panel beaters then a good clean out before paint.
Hi all,
Quick update on my 61 - body and chassis has been separated, waiting and deciding on panel beater/painter still. Until then the body is sitting and
waiting.
I've had the chassis degreased and steam blasted, onto replacing floor pans next. Have decided to go with original 18 gauge steel instead of thinner
ones.
I now need to start putting in some orders for chassis parts, does anyone have experience with the different suppliers?
- vw heritage
- Volks.com.au
- just campers
- dasresto parts
- Mick motors
USA
- Wolfsburg west
- CIP1
Any help on quality, pricing, reliability would be much appreciated.
