Paint Help
BlasterTheRedBajaBug - December 31st, 2016 at 10:39 AM
Hi All,
I am looking at a few colour choices and wanted to know which one will stand the test of time a little longer.
The colours are; Aubergine Purple seen on Lotus Exige's, Soul red seen on mazda 3's or celestial blue seen on mazda 3 mps's.
I would also like the most "WOW" colour and am open to other colour options as well.
Also which one would hold up better in the sand if I wanted to play about there.
Thanks.
Governor - December 31st, 2016 at 06:35 PM
None of them will hold up off road even in sand as two are metalic and the other is pearl.
Chose a solid colour, easier to repair if you get scratches ect
BlasterTheRedBajaBug - December 31st, 2016 at 09:12 PM
So I have found the factory colour and think it looks better as it is solid so how do I go about sourcing it.
BlasterTheRedBajaBug - January 3rd, 2017 at 09:55 PM
Bump
psimitar - January 24th, 2017 at 05:30 PM
I'd think 2 pack would stand up well to sand. Acrylic not so well. Metallics would require the entire panel resparyed if damage occurred. Wouldn't matter on what type you used, Acrylic or 2pack.
Factory colour is easiest to use the colour charts on Wolfsburg Wests website. Reason being that VW Oz build sheets were destroyed so you can't get the original colour from the birth certificate from VW Germany.
BlasterTheRedBajaBug - January 26th, 2017 at 12:56 PM
I have thought and thought and thought some more and I think that the Aubergine purple would look good because I would only take him to the beach every now and then so it would be mostly a road car.
Also would it be a good idea to do painted tappet covers and fan shroud or just chrome?
adlbeetle66 - January 26th, 2017 at 03:43 PM
Just a tip, i've heard from a few different people that the chrome'd tin pieces often trap more heat and make the engine run hotter - someone can confirm that??
BlasterTheRedBajaBug - January 26th, 2017 at 04:12 PM
so painted would be "better" than chrome or being that the engine isn't covered would chrome have no real effect?
barls - January 26th, 2017 at 07:03 PM
just remember if there was a substantial benefit from chroming the tinware they would of come like that as stock.
from what I've read its exactly the opposite it will help contribute to an early engine failure. hence the saying chrome won't get you home.
DubCrazy - October 1st, 2017 at 10:40 AM
old post i know but not sure if u sorted it..
chose what ever colour u like it will make no difference as long as you use a decent brand (not super cheap/autobarn stuff)
i did my baja in a 3 layer pearl and used a high end cermiclear, the cerami clear when fully cureded is a highly scratch resistance product... i had mind for 3 years and may times had branches and other stuff hit it, apart from a couple of rock chips it held up seriously well....
don't use acrylic its weak, only use 2k... no matter what colours you chose the cerami clear will hold up better than another clear or solid colour..
i used ppgs D8122 ...
steff
DubCrazy - October 1st, 2017 at 10:43 AM
Taken just before sale. 3 odd years of abuse and still looked great. Never garaged always lived outside.
Steff
BlasterTheRedBajaBug - October 1st, 2017 at 02:46 PM
Hi Steff,
Nice car, I have sold my baja and bought a purvis eureka now and I think I have chosen to paint it a metallic teal like the new toyota chr.
