Fiberglass filler ?
seagull - October 9th, 2004 at 12:21 AM
I doing some body work on a fiberglass body , what is the best filler to use ? I going two pack paint and would like a quality job at the end , cheers :beer
helterskelter400 - October 9th, 2004 at 12:32 AM
sorry neil,
"two pac and quality job" counts us leftover bog & acryilic demons out...
once again no help at all.:jesus
Skinnyboy - October 9th, 2004 at 01:52 PM
you can get 2 pack fibreglass filler from most auto shops (Bursons, Repco et al..)
we use it in work for fixing crappy fibreglass kits that most youngsters have on their rice racers.
Its sandable and best finished with a thin skim of 2 pack bog, then fill in any pinholes with fine filler, finish of with 180grit then feather with 240. then primer and spray!
Hope that helps.
Anthiron - October 9th, 2004 at 06:45 PM
ive used K+H Kah Glass 2 part filler and it worked well.
username - November 6th, 2004 at 06:53 PM
The best stuff to use for filling fibreglass is a filler called 'Balloons', it is powder based and you add it to the fbreglass resin (Vinyl, Polyester or epoxy) and make it to whatever consistancy you like to work with, wait over night then sand. This filler not only seals but adds strength back to the damaged fibreglass. This stuff is available rom a wholesaler such as 'RF fibreglass sales' or 'Saint-Gobain Vetrotex'
5PL1TDCS10N - November 6th, 2004 at 07:53 PM
Hey N,
I have to get more supplies this week so I'll find out what you need.
I use Soudal bodyfiller and happy with it...
seagull - November 7th, 2004 at 12:35 AM
Ok Thanks mate
Stanley - November 7th, 2004 at 12:49 PM
I've got a boat with some chips in the gel coat.
What can I use that wont require to much sanding and no painting.
Don't want to ruin the finish around it.
[Edited on 7-11-2004 by kafer69]
barls - November 9th, 2004 at 06:03 PM
polyester resin with glass balls
