I;m currently repainting my 61-62 beetle and need to find out the original colour.. it's a sorta off white! Not much more i can say. Hope you can
help.
Ross
PS. I need to blend in with the original so i need an a code or something similar
[ Edited on 17-11-2005 by Ross ]
I know they ran lotus white around then.
The paint shop you are getting the paint from should definitley be able to help. In fact if you have any panel off your car you can take it in to be colour matched, or even the beetle itself if it is drivable.
Cheers man... should that be accurate enough...taking a panel to a paint shop?
No probs at all. Quite often they colour match to a small panel like a petrol flap, but as your beetle is 61-62 it wont have a flap.
Fantastic! thanks man!
