Now I'm no expert but I notice a lot of people doing body work and then hitting it with some primer etc.
I find the primer is not really good to leave the car in for a long time as it still attracts moisture.
I had rubbed some of my car back to bare metal and primed and I ended up rubbing it back again to bare metal to find tiny spots. ( start of rust ) I
was using a top quality primer but the car has sat for a long time.
So now I'm just going bare metal all over and treating with Metal conditioner DX 520 SG which is a PPG product.
I find this will also let the lead work on my car breathe also.
Anyone got some thought or better suggestions?
yeah after you have primed the area hit it with a light coat of spary enamel any colour
this will hold the surface but not good for a long time
Its easy to rub off late when yr doing a final prep b4 paint
Yeah I thought of that but it just seems like twise the work.
I think I just need to spend more time in the shed and get the shell finished.
well that will always help too many interuptions mate
give it a squirt with some flat Black its easier to rub
n onl;y a pissy spary OK :blah:blah:blah:blah:blah:blah
And take the fridge out of the shed! LOL
Hi Bugboy,
Have you tried 2pac epoxy etch primer? That works really and keeps for years.
W
took some panels off the 58 split and as i was twisting it off some bog bounced off leaving bare metal that seemed to have been lacquered wit clear at
the time
well some time in the last 40 years or so...no rust there even though it has in other places as it was under a tree
maybe 25 yrs
now am gunna see what happens when i wet it
wow.....
I'm screwed :jesus
If it was me I would use Dp 40 It is a PPG product an Epoxy Primer. As long as your metal is clean. It is poly eurathane based, which means you can do
your filler work ove rit and then re sseal it as well stop and moisture this should a long time and save doing the job twice !!
Matt
light coat of rust paint seems to work fine, if not do small bits, prime then coat with any top coat rattle can, then move on, strip the whole lot, when your happy, then spray for the final time.
