Hi everyone,
Just wondering what all your thoughts are on rust converter?
I have a few areas on my ghia that have the pitted metal look happening. These areas are still nice & strong so am thinking that cutting out and
replacing the metal may be a tad drastic, which has led me to look for a chemical solution.
Should I go for a rust converter and if so, which brand?
Should I buff off all the surface rust first before applying it?
And what do you guys recomend with regards to prepping after treatment?
Cheers,
Cam
i use REVAMP rust converter.. have so for the past 20 yrs and it works like a treat.. revamp + rust = dead rust..
Thanks for that, will look into it. How do you go about prepping the surface?
I found this:
http://www.theruststore.com/How-To-Use-Rust-Converter-W29C2.aspx
But it's not really accurate with regards to if I take it all back to bare metal or leave surface rust (assume the latter) and then the preparation
for prime & paint.
