Hi,
I've got a 1964 Beetle that creaks and the doors sometimes pop out when I got over a big pothole.
I'm thinking of giving it a repaint. I have a cousin who works as a professional panel beater and he's offered to lend me a hand.
He wants to do a through job- and is going to strip it down to bare metal, cut and weld any rust spots.
He wants me to get the gromits and rubbers for the VW to make his job easier.
I've alrady got the fender rubbers. Is there also a body rubber for the chassis + car shell? What else should I get?
Yes, there is a rubber between the body and pan, but you probably won't have to remove/replace it. You can buy every rubber from a VW specialist
Sort out why your door is popping open befoe you begin any other work. Is it rust wekending the body? Or just a matter of adjustment?
i would replace the 4 door hinge pins b4 u do any work otherwise you wnt be able toadjust and align the doors up correctly
make sure your door lockas are good they tend to wear you should be able to hold the lock pin in and not push the striker plate up at all
