Can someone please tell me how many holes there are in the side panels of a early S Beetle for the chrome strips. Maybe some distances too if you have
a few spare minutes. Can any one offer some tips on this job?
Many thanks, Brad.
The front quarter panel has 3 holes. Looking at mine they are at 25mm, then 325mm then 625mm forward from the A pillar. The door and rear quarter
panel have 5 holes but I am not sure of the hole spacings on them. It looks like about 50mm back from the A pillar on the door and the same back from
the B pillar for the rear quarter pane for the first holes.
Hope that helps.
Yogie
If your using the narrow strip get some new plastic clips they work well
Thanks Yogie that helps heaps.
I ordered the body molding kit and clips from CVW. I think they might be the plastic clips.
So, what year beetle are We talking about???
the late models 1968> had the narrow strips
either aluminium or stainless steel
and plastic clips...
If the clips you get are not Wurth brand for get about it they will fall of within 6 months
If I were going to add a chrome strip to a beetle, I wouldn't drill holes and use clips. I think it would be better to use double sided tape rather
then hacking into the body. Also, you can always remove it if you dont like it or a change with the seasons or reposition the strip if your door
drops. Just my 2c worth.
Kev
i replaced them on my Lbug when i resprayed it and its the same as Sbug and there was 30 for both sides
front and rear quarter panels and both doors all have 5 clips each and bonnet had 6 clips
