How do I remove the chrome molding strips on an early beetle without damaging them?
Rob
The safest way is to tap the back of the clips from the inside [gently]. Front 1/4 panels are easy to get at, but door and rear 1/4 trim cards will
need to be removed first.
The moulds can be levered off without hitting from behind, if care is taken not to bend them, and not to scratch the paint. They all 'push' in - no
nuts behind.
Running board clips must be twisted so that the moulds can be removed.
Quote: |
No different beetle, this is a '66 with the wide alloy strips.
Thanks guys.
i use a paint scraper under the trim and close to the clip
but if you can get to the back of them as per above makes it easier
cool i'll keep that in mind
