Can someone advise where to get weld through primer - I have asked al few places whom I thought would know and they just looked at me strangely.
I use Wurth weld thru, could get some for you if you can't track any down
Couldn't find it at supercheap pete?
And you had to speak for them
to look at you funny? Thought standing there would be enough
Thanks Matt, I will see how I go with that brand.
Col - I didn't think supercheap sold anything but caramellos ..
Oh and have a new toy
any zinc rich primer above 90% will be a weld able primer.
You can get two different types from here.
http://brisbanerefinish.50webs.com/brslocations.html
They are also very good to deal with (the archerfield one. Can't vouch for the others)
I use this one by the way.
http://www.techno-vent.com/store/index.php?main_page=product_info&product...
Really good stuff, leaves a lovely copper colour that made me want to clear coat it.
$25 per can.
Cheaper option??
I bought the gear that you recommended Brad - Matt couldnt find your stuff. Like always you go in for one thing and walk out with six.. the kids can
eat baked beans for a night or two.
I will get some pics up tomorrow if I get home in time - I quickly applied some afternoon, but was too late for photos.
I can see why you liked the colour.
Peter
I have found ti does work well and does not seem to affect the weld that gets layed down on top which is good.
As far as long term protection, I don;t know. I figure it will be good to have in the sills and folds that I wont get to later and being copper based,
it should by rights, melt and then solidify as part of the weld when it cools.
I know VW used to braze certain areas like the roof to a pillar join, but then VW also made a bunch of cars that rust to buggers after 30 years? So
who knows???
Hi Guys,
When you apply weld though primer, is the idea to keep it very thin, or is it not such an issue?
I was planning on applying weld through primer to the tunnel lip before fixing new pan halves.
On some test pieces, the plug welds look ok when it is on bare metal, but when I use Camweld on the tunnel lip,they look down right crappy and at
times leads to the top plate burning away.
Newt
I find the Zinc based weld through primers to work well with electric resistance spot welders
When doing MIG plug welds I find that Copper based weld through primers spatter less.
I have only used copper.
You could get around it by giving it a good coat behind the steel then tacking in place before giveing it a light scrub on the weld join from the
outside, cause at the end of the day you will be sanding/grinding the weld flat anyway before paint.
It really just gives us a warm feeling knowing the back of the steel has some protection incase we accidentally miss the area with fish oil later.
