my first engine pull- new air box? MOTOR BACK IN
turboty - February 25th, 2013 at 09:09 PM
[size=4] ok so I did my first!
So I pulled the motor out of my bug/porrera... not too bad... took 1 hour,
So yeah, the bolts werent in the engine bay... but found it all... have now stripped most of the parts down. So I can paint all the tin as it not in bad nick...
I would like to change the air filter to a single on the stock carb any recommendations?
Tyler[/size]
sander288 - February 25th, 2013 at 09:36 PM
Congrats on the engine pull; its always satisfying when done without fuss and easily.
If you have a stock motor keep the stock filter (not sure what you have...)
turboty - February 25th, 2013 at 09:44 PM
Umm not real sure what done to the motor, is got the big oil sump thing flat square one, oil cooler, empi exhaust, new push rod tubes... and that all I know... it is a porrera kit car,,, has chrome fire wall and left and right of the motor, as I am spraying the bits you can see black, just wanted to get rid of the massive 'stock looking air box'
I like the rectangle scat style ones, what do I do about the auto choke ie cold start stuff...
matberry - February 25th, 2013 at 10:03 PM
Stock carb will work best with stock air filter
turboty - February 25th, 2013 at 10:04 PM
so i just went out a took a photo of the carb, a solex 34, is that stock on a 1500?? here is the pics anyway.. so yeah i just want to get rid of the old MASSIVE box and put something nicer on?? maybe chrome to match the other colours in the deck already...
turboty - February 25th, 2013 at 10:07 PM
so something like this is no good??
http://www.ebay.com.au/itm/VW-Beetle-H-Flow-Air-Cleaner-VW-Stock-Carb-9121-/3...
matberry - February 25th, 2013 at 10:12 PM
Depend if you like shit parts that make you VW worse
sander288 - February 25th, 2013 at 10:14 PM
Any filter you buy will work ok with a stock carb; but in terms of filtering, cold start pre-heating, connection to breather and in alot of instances performance the stock one is better for a stock carb. If yours is an old oil bath filter they have a built in velocity stack.
turboty - February 25th, 2013 at 10:18 PM
just an example... any tips would help...
matberry - February 25th, 2013 at 10:29 PM
See Shauns's post above. He is ontoit
barls - February 25th, 2013 at 11:33 PM
Previous threads
http://forums.aussieveedubbers.com/viewtopic.php?tid=96857&page=1#pid925399
http://forums.aussieveedubbers.com/viewtopic.php?tid=87276&page=1#pid813880
http://forums.aussieveedubbers.com/viewtopic.php?tid=84917&page=1#pid792501
http://forums.aussieveedubbers.com/viewtopic.php?tid=84141&page=1#pid783237
http://forums.aussieveedubbers.com/viewtopic.php?tid=83431&page=1#pid776190
http://forums.aussieveedubbers.com/viewtopic.php?tid=80954&page=1#pid767954
turboty - February 28th, 2013 at 09:53 AM
hey guys got the motor back in and running... i think i missed my calling...lol
grumble - February 28th, 2013 at 08:11 PM
You may have but be warned it is a tough way to make a living and if you have to charge for the hours that you spend on the job,actually get the money,give 90% of it to Govt departments,taxation , pay the rent,electricity,licences insurances and anyone else who thinks they are entitled to some of it you will go broke in a hurry.:crazy: Stick with what you are good at.
Craig Torrens - February 28th, 2013 at 09:50 PM
Looks like yours is a twin Port 1600.........not a 1500.
Joel - March 1st, 2013 at 12:50 PM
You are far better off getting rid of that remote oil cooler, its actually doing more harm than good.
It would be getting bugger all air flow at all where it is and its just heating up the fan intake making the engine run hotter.
Replace it with a remote oil filter, that engine will thank you.
an engine like that only needs the stock oil cooler.
turboty - March 1st, 2013 at 10:14 PM
How do you tell?
turboty - March 1st, 2013 at 10:16 PM
Would I put the fliter in the same spot or somewhere else...? Also what would this filtrr help with? Any links I can look at?
barls - March 1st, 2013 at 10:40 PM
the manifold is the give away. as it has two ports each side.
as for the filter, its to increase the lift span of the engine by better filtering the oil as opposed to the strainer thats fitted as standard
turboty - March 2nd, 2013 at 08:42 PM
So they dont make a twin port 1500...
Craig Torrens - March 2nd, 2013 at 10:17 PM
Factory twin port motors were 1600 or 1300..........not very many 1300 out there though.
turboty - March 3rd, 2013 at 08:54 AM
Great thanks for the good information! Im in the 1600 club now
turboty - March 3rd, 2013 at 01:42 PM
Mexico AS41
D or 0 43.101.102 A
Found under the motor near the push rod tubes...on the right side oh the motor... is this a 65hp 1600 twin port?
