Vdo fuel gauge
Das Green Machina - September 11th, 2013 at 11:29 AM
G'day
I have recently changed my fuel tank and now the fuel gauge wont work properly is there anywhere in Sydney I can get it fixed ? Does it need to be
reset? Recalibrated? Any advice?
Frank
beetleboyjeff - September 11th, 2013 at 11:33 AM
Check that the sender has a GOOD earth.
68AutoBug - September 11th, 2013 at 12:06 PM
Originally
posted by Das Green Machina
G'day
Frank
when I did this Frank, Mine didn't work either..
the tank was insulated from the body..
I added a wire from under a screw on the fuel sender to the body with a small self tapper screw, or You can put it under a screw that is already
there.. it just needs to be grounded..
Das Green Machina - September 11th, 2013 at 12:36 PM
Thanks for the help I'll have a go at it this weekend.
vduboy - September 11th, 2013 at 01:12 PM
Airco at Marrickville are VDO dealers mate, I took my speedo there when It was being dicky 5 years after I bought it and sorted it out for free.
