type 3 engine same as bug?
chargeroz - October 23rd, 2014 at 07:43 PM
hi people can onyone tell me if a type 3 engine has the same crank as a 1300-1600 beetle?
grumble - October 23rd, 2014 at 08:33 PM
Yes the crank is the same only the case is different but can be modified to suit.
chargeroz - October 24th, 2014 at 07:22 PM
whats the differance between the cases ?
grumble - October 24th, 2014 at 07:39 PM
The dipstick hole isn't drilled as the dipstick is in the filler tube and the oil pressure line has a blanking plug fitted.These small obstacles can be overcome fairly easily.
chargeroz - October 24th, 2014 at 08:27 PM
cheers mate.. learning again its been many years since i touched a vw ....
