Hi guys, wondering if anyone can steer me in the direction of someone who can supply/make wheels in Sydney (or thereabouts) in a VW 4x130 PCD but with
the correct offsets as not to piss off the engineer?
Just got my 6 inch vw wheels back from the 'fabricator' after having the offsets corrected and they are wobbly as all crap! easy 10mm of runout, and
they were straight when I sent them to him...
So trying to get them repaired but if they are stuffed then I will need another solution.
Any clues are much appreciated!
Have you tried Morton & May?
I called them today but couldn't get there from Hornsby before they closed, will be seeing them if my frame/wheel guy from work cant do anything with
them.
Cheers.
AJAX wheels in Moorabbin VIC are gurus, and have modified and supplied wheels forever. It could be worth calling them and freighting them to get the
info and get the job done right.
http://ajaxwheels.com.au/
10mm runout? holy shit, really? that bad?
thats bad. i thought 0.1mm was bad but this.
Just to fill in a gap in this, the wheel assoc standard is 70 thou runout (1.7mm), mercedes on the other hand is 1.0mm. Runout measurement needs to be done on a trueing stand not a balancer, have seen some great discrepincies over the years.
damn thats a lot for standards.
i've never seen any on alloy wheels of mine, fraction of a mm at the most on steel due to manufacturing limitation obviously certainly not close to a
1mm.
