Hey fellow vee dubbers i just bought my self a 65 beetle fully restored and wanted to do a minor service on it like oil and spark plugs, What oil
should i buy and same with the plugs?
thanks again...
PS: Can't wait for dubs at the pub
I use Bosch W8AC plugs and Castrol GTX2 oil.:P
FWIW
I use BP Visco 5000 synthetic oil and NGK Iridium plugs in the 'Vee.
L8tr
E
I always used Bosch plugs in the VW's and NGK in the bikes and EH until I got a set that were made in India (maybe that's where they are
made now), and within 4 weeks one of them dudded out.
Now I only use NGK.
I buy my oil in 20 litre drum and service all the bikes and cars with it as it amazingly is correct for all 5 vehicles.
glad to see youve finally come to your senses and bought a VW!!!!!!!
:bounce:bounce:bounce:bounce:bounce
:alien
bump
I run the aforementioned Bosch W8AC plugs and Mobil Super XHP... same grade/class stuff as GTX2... and Porsche use Mobil (albeit Mobil1) so, "why not", I say...
I use castrol GTX 2
Take into consideration the age of your engine for the oil you use.
And don't use for gods sake champion plugs, their gauranteed to seize into your heads
NGK iridium NGK iridium NGK iridium NGK iridium, these plugs rock, my engine used to foul plugs all the time(changed plugs every service), put a set
of these in and hase been running fine for 10000km and the plugs still look new. They are a bit exxy though $20 each.
Use penrite deisel (spelling?) oil. for my moded motor, the stock 1600 and the pajero. Buy 120L a year from supercheap when they have 20% off sale!!!
castrol gtx 2 and bosch. ngk if you're at autobarn.
castrol formula r is good for slightly funner motors.
Yes I use GTX2 castrol engine oil and will be changed at every 5000kms.
I have Beru spark plugs in My engine at the Moment.
I always used Bosch before, but I have heard that Bosch plugs are no longer "as good as they were"...
NGK are the best plugs, I may go for them next time..
and as someone else said - Don't use champion spark plugs-
Firstly I wouldn't trust them. I have heard of failures, plus their spark plug thread shape is slightly different to the normal metric thread and
they tend to bind in the alloy..
One Other TIP... I always use Anti Seize on Spark plug threads to stop them from seizing or being hard to unscrew.
as the Alloy expands differently to the steel spark plugs...
Welcome to Vee Dub World...
30 or 40 weight oil? Or 50? I'm using 40 at the moment and change it when I feel like it (i.e. last time was after 2500ks cause I had a day off). Car runs cooler and better.
