ok i was told before to make sure they are dual "IDA"
how do i know if they are ?
also how much are they worth ruffly ??
i have one of them in my lap right now so i should be able to see what ever gets mentioned
thanks guys luke
even a link would help too, i should of mentioned that up there ^^^^^^
oh yeh bump
On the bottom of the casting (where the carb bolts down) it should have the size and idf/ida/dcnf etc, there are a lot of types, if you can post a pic we can identify it..
will do it'll be up in 5 mins
while posating these i found on the opposite side just undr where it appear the fuel in line is it sez : 40 idf 18 0L. is that the info that you
were talkin about ?
Early model IDF carbs
roughly 600 give or take some.
would these suit my 2ltr kombi or give it any noticeable power gain ?
yes they will suit and give you some extra power
so whats the 40 idf 18 0L stand for ??
not sure about the 180L 40 is the size (40mm) the chokes have also been blanked off on that one (wont hurt them)
thanks guys :beer any idea how much a set is worth ??
the guy hasnt said a price yet so i just want to know a ball park figure on them so i know what ruffly to expect.
thaks again. luke
one last bump
thanks for all the help anyways guys, always good to learn from others
cheers :beer luke
For what it's worth, my webers gave me 1 hp more than my Kadrons, but gave me most of that power over a greater rev range, rather than the Kadrons having (almost) the same peak power but only for a small rev range. It made the car feel faster and more responsive. The down side is I'm at the moment using a RIDICULOUS amount of fuel. I have to sort that out. They cost me around $700, but were newer than these.
I paid $800.00 for mine , they were all serviced * glass blast* c/w new kits, they had new K&N air cleaners fitted .
I would say a fare price for what you have there would be $400.00 > $450.00
thanks for that one guys, as for the fuel consumption oasis my bus guzzels it now and no one knows why so im hoping that we might be able to sort the
webbers out a little better
Check the throttle shafts, old carbs wear between the body and the throttle shaft, if you have an airleak there they will constantly fall out of tune.
To get them rebushed can cost more than the carbs are worth... If you have any lateral movement around there I would give it a miss.
The numbers after 40idf relate to themodel of idf. They had different circuits and emulsion tube set ups dependant on what they were originally on.
Some will run better than others on a VW .
