I was just wondering if anyone can recommend a car that has inertia seatbelts suitable to put straight into my L bug? I once heard that late 70's Corolla belts would go right in? I'm just worried that where the reel goes would be a tight fit in a bug.
heres what i do mate but it does require a engineers as it doesnt use the stock points
http://www.aussieveedubbers.com/forum/viewthread.php?tid=26426
Thanks for that. I saw that one I while ago, good job. It is what I will probably end up doing as there really is only a small amount of room near the existing lower mount point.
i put VL commadore seat belts in my oval. it worked nicely, just had to change the shape of the bracket a bit so it could be bolted to the floor!
