12volt to 6volt resistor
NCH-003 - August 5th, 2005 at 10:47 AM
Hi all have just on the road a 67 Australian Beetle which has been converted from 6 to 12volt.Just wondering where i would get a resistor to drop the volts from 12 to 6volt so i dont burn the wiper switch out.
At the moment you turn them on there fine turn them off they keep going.
Any help with this problem would be great.
D
tassupervee - August 5th, 2005 at 11:46 AM
Dude
As far as switches are concerned, for the purpose of your exercise, it makes no difference what you use. 6, 12, 24 or 240 volt! to a certain extent, switches are switches.
Im presuming that the wiper motor has been replaced with a 12 V item yer?
The issue of the wipers remaining on after they are switched off should have very little to do with the actual switch you are using.
L8tr
E
blutopless2 - August 5th, 2005 at 01:12 PM
as stated above ^^^^^
The switch would not be the issue. The motor would be if it hasn't been converted to a 12 volt motor. It will just run really fast and because it runs so fast when you want it to stop it takes a while because there is little resistance to slow it from the wipers.
here is one i found on classicveedub website.
NCH-003 - August 5th, 2005 at 08:54 PM
thanks for all your help on this...
