I've currently got a 1500 grearbox with (i'm presumiing) a 4.125 final drive ratio. With the on set of smaller diameter rear tyres, i'd like to
keep my top speed and efficiancy intact.
How much work is it to replace the final drive? Can it be done at home or does it need lots of "VW tool number ####" to get it done properly?
It needs all the special tools
dam.
How much do ya rekon a garage would charge to do it if they supply the R&P? (ballpark figure of course)
[ Edited on 31-10-05 by oval TOFU ]
Be cheaper and easier to change your tyres first, considering these are the final "gears" that determine the outcome of speed etc.
What size tyres do you have on it now?
What final drive did you want to go to anyway?
What were you hoping to gain from changing the final drive?
you've got some big boots under the car already!! 225's, that would fill the guards nicely:thumb
I gather you've got a swing axle, thus the ratio change request...get another quote/opinion, maybe have a chat to Wayne Penrose as he build's boxes
as shown in his oval build up.
http://forums.aussieveedubbers.com/viewthread.php?tid=36521&page=3#pid335130
Chris
I'll have a dig for the number of the guy who built my box I started with a 1500 box and put shorter axels in I also played around with the final
drive ratio I changed it for a kombi 0.60 from memory this will give me slightly lower revs in fourth gear ie taller top end for the freeways.
Hes been building gearboxes for VW's for 30 odd years so knows his shit plus has all the tools.
I'll find his number for you in the week by the way hes good on the pocket
nIck
Thanks for the leads guys.
If you can have a dig Nick, that would be great. I'm going to contact my original builder to see what he says again and to address some shifting and
oil leaking issues and we'll see what happens..
