removing front seats of a 1973 bug
white_bug - December 21st, 2005 at 01:02 PM
hi all,
i am attempting to remove the front seats of my 1973 bug but cant seem to find a way to get them out. any info would be great.
Midlife crisis - December 21st, 2005 at 01:07 PM
from memory when you slide the seat forward as far has it will go on one of the slides there will be a latch that will move and allow the seat to come out
Hope this helps
Marc
white_bug - December 21st, 2005 at 06:11 PM
so it slides of the rails???
i read that to get the seat to slide of the rails there arre some clips that need to be removed. would you know ne thing bout that??
Midlife crisis - December 21st, 2005 at 06:22 PM
The latch is attached to the rails that the seats slide on, the front of the rail on the tunnel side if you slide the seat right forward and have a look at the side of the seat look down to the floor next to the tunnel you will see a flat bit off steel about 3cm long push it down and the seat will slide forward and off the rails.
I just went out and looked at my BAJA
Marc
