Wiper motor wiring...help?
boof2332 - February 7th, 2006 at 10:33 PM
Just rewired the mess under my dash and have smoothed the whole dash leaving only the speedo. Subsequently have changed all switches. There are 4 pins on the wipers...two at the bottom, then two singles above each other. I tried to test with a light before removing, although was unable to establish what was what. Any help would be great...
Matt
vw54 - February 8th, 2006 at 06:46 AM
Have you got the origional coloured wiring and switches I can check mine if you like
boof2332 - February 8th, 2006 at 09:47 PM
Unfortunately the person previous to me sprayed the whole lot in the old green. If you can just tell me which are earths...on the wiper.
Matt
vw54 - February 9th, 2006 at 09:39 AM
the earth is the brown wire get some thinners n wipe the paint off or scratch it off with a razor v blade
or get a mulit meter n see which wire goes to ground
