Just purchased a Kombi to go with the notch... It's a camper without the pop top.. with a hatch for the gas bottle and vents behind where the stove
should go.
I have a pop top one ready to go on. Can anyone explain what's invlolved, the degree of difficulty and any tricks? Help much appreciated.
Do u know wat sorta poptop u got to go on? Sopru...etc..??
I have removed/refitted mine (to stop some rust).... and by looking at what was done originally, seems like a fairly easy sorta job...thats if you
have the gear to cut the metal..!?
need to have a good insulating rubber to run around the edge of the poptop to stop water and dirt from creeping in...
good luck.
Craig.
