can you fit a 1600sp into a 56 oval?
Yep, but you will need to modify the rear tinware to get it in.
It is a tight fit though. Plenty of people have done it.
thanks, wasn't sure the gearbox/starter motor would work.
They wont. You will need a 12V starter and starter bush and to grind out the bell housing. You will need to convert the rest of the electrics to 12 volt.
Ahhuh!!
Now we know the full story. The engine will fit, as long as you make the necessary mods to the tranny setup.
Maybe I should of elaborated.
whats up guys...just startin off...playin with beetlez.im in need of some engine pics of a 1500 beetle.want to strip off heads and i dont know how!HELP!Regards........... ray in south africa
If the 1600sp is 6v then there is no need to change the starter or any of that stuff. The difference is the flywheel (6v being smaller) so a 12v
starter will not work on a 6v flywheel and vice versa. However if you have 6v fw and starter you can safely run it on 12v as i have done for ages.
the starter motor just runs a little quicker.
Hope this helps.
Ian.
